The toggle switch (that controls constant on, or intermittent action) has broken in my foot pedal. Here's the exploded diagram:
http://www.crowleymarine.com/mercury...s/7768_170.cfm
Part 19 is the broken switch.
The replacement process looks really simple, if I could only figure out how to access the switch. It looks like I have to take the pedal off of the base; it's held on by a pin rocker (part #24) that I should be able to drive out from either side of the pedal, but it is held in place by two e-rings that I'm not sure I should remove.
Any ideas on the best way to get this done?
Thanks!
Tim
