Results 1 to 2 of 2
    Default 3HMF with greyish oil & leak
    Hi,
    I noticed after Spring launching that the oil in the engine had turned a greyish color. I put in fresh oil and after running it a number of times, it has turned that way again and is not as viscous as it should be. It is also oozing oil out of the parallel pin on the top of the engine (see pic of greyish oil leaking). When running the engine, I do not see any liquid dripping from the engine and I watched closely at the impeller pump and it seems to be running OK with no external leaks. I'm guessing water is mixing in with the oil somewhere. Does anyone have any thoughts on what the problem might be?
    Thanks so much for your input!
    Steve
    Feb 2014
    Kitchener Ontario
    19
    Default Re: 3HMF with greyish oil & leak
    Remove and inspect the water cooled exhaust elbow, there are two types a down angle aprox 45 degree and a up down gooseneck.This elbow may have corroded in side allowing sea water to back in to rear cylinder and into the base.
    Rare but not impossible is the exhaust manifold then the cylinder head
  1. 3HMF Zinc
    By SomeIn in forum Yanmar
    Last Post: 04-28-2012, 01:00 PM
  2. Bf2 oil leak
    By [email protected] in forum Honda Outboard Forum
    Last Post: 06-14-2011, 02:22 PM
  3. Oil Leak
    By bailey05 in forum Yamaha Outboard Forum
    Last Post: 07-14-2010, 02:46 PM
  4. Oil Leak
    By viphtcb in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 06-15-2009, 05:22 PM
  5. Gas leak
    By debtimfish in forum Johnson Evinrude Outboard Archive
    Last Post: 03-06-2006, 09:36 PM
