Results 1 to 4 of 4
  1. #1
    Post Help with Timber Decking & plywood on my Tinny??
    I have a 11ft V hull tinny and want to put a flat timber floor across the bottom what's the best way and how to run my timbers and plywood I would appreciate some help peoples thank you..
  2. #2
    Join Date
    Dec 2006
    Location
    Greenfield Me. USA
    Posts
    6,296
    Default Re: Help with Timber Decking & plywood on my Tinny??
    Quote Originally Posted by Yeh Yeh View Post
    Ayuh,.... Welcome Aboard,..... There's a Problem with yer plan,....
    Yer little tinny has a very low Weight Limit,....
    With a timber deck, ya raise the center of gravity, as well as add a tremendous amount of Weight,...
    She'll be Over-weight by the time ya step into her,....
  3. #3
    Quote Originally Posted by bondo View Post
    Check out my boat
    http://flic.kr/p/nQyfeu
  4. #4
    Join Date
    Dec 2006
    Location
    Greenfield Me. USA
    Posts
    6,296
    Ayuh,.... It's Yer boat, 'n ya can do whatever ya want to it,...
    I'm only pointin' out that it's a bad idea for various reasons,....
    If ya add weight, you can put less stuff in the boat,....
    If ya raise the deck, the center of gravity rises also, causin' it to become very tippy,....
    There's No reason for PMs either, that's what this thread is for,....
Similar Threads
  1. Motor Mount ShimsTREX DECKING
    By knuckle47 in forum Crusader Marine Engine Forum
    Last Post: 09-22-2009, 09:14 AM
  2. Is this CDX or BCX plywood
    By weider1717 in forum Mercruiser Sterndrive Archive
    Last Post: 01-28-2009, 11:44 AM
  3. Stringers from plywood
    By masterbaiter88 in forum Mercruiser Sterndrive Archive
    Last Post: 01-07-2009, 06:37 PM
  4. Plywood
    By a1nowell in forum Mercruiser Sterndrive Archive
    Last Post: 05-16-2008, 10:06 AM
  5. AQ130 270 Rattling tinny type noise
    By uno759 in forum Volvo Penta Gas Archive
    Last Post: 12-01-2006, 11:30 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
