Chris Wilson
Hi everyone, I've been around boats most of my life but this is "my" first boat. I just bought a 1988 Rinker 240 festival cuddy... 305 with alpha-1. The boat is originally from Michigan and trailered here to Florida a few years ago. It has sat and never touched the salt water. The engine and sterndrive are in really good shape and not rusted so I believe it. The previous owner says the impeller in the outdrive had just been replaced before it was winterized 2 yrs ago. I put it in lake tarpon last weekend and is overheating at idle, but when you get on plane it will cool down. My train of thought is that the impeller in the drive is pumping water up to the engine, but the engine mounted water pump is inefficient, and needing the additional rpms to pump enough water to cool it. I have turned wrenches most my life is an ASE master Tech, But boats are quite a bit different.
Any thoughts as to why it is cool on plane and overheating at idle? How can I test the water pumps to verify correct operation. I pulled the top plate off the thermostat housing, and the thremostat was wide open. I ran the engine to see how much water flow I had at idle (on the hose) .... I did have some flow, but honestly expected more. I'm not one to throw parts at a problem...but I'm leaning towards the engine mounted pump... I assume this pump could not prime itself sitting in the water without the help of the stern drive impeller so the stern drive I pump must be doing the pumping.... Additionally what are the balls and springs in the thermostat housing for?
Thanks so much!
Chris
Thanks so much!
Chris
