Hi I have two fuel injected honda BF90s. They recently started leaking water out of the side covers. I took the covers off and found that it is coming out of two holes in the oil pan where the drive shaft goes up through to the powerhead. I replaced the water pumps and also the grommets that are in the 5inch spacer that goes on top of the gearcase. It is still leaking a lot of water. I noticed that if I take both thermostats out it will barely dribble out if not stop completely. Any input would be greatly appreciated. Thanks!
