Results 1 to 12 of 12
  1. #1
    Question Closed circuit cooling of Interceptor 289
    Was wanting some information on installing a heat changer on my 1964 289 Interceptor I want to put a circulation pump on the engine I am assuming I would have to change the timing cover to install the new pump and to fit the fuel pump?
    Any info would be appreciated
  2. #2
    Default Re: Closed circuit cooling of Interceptor 289
    If the engine was ever used in salt water, it is not advised to go to fresh water cooling.
    My Motto Is:
    K.I.S.S.- Keep It Simple Stupid!
    Or, It Might Get Real Expensive!
  3. #3
    Hi, from what I understand it has never been in salt water and water jackets look pretty clean motor runs real well but live in Auckland NZ surrounded by saltwater!
  4. #4
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,709
    If you do install a Closed Cooling system, do this:
    After approx 20 hours run time, remove the H/E, perhaps even shake it up a bit, and dump the coolant into a clean white bucket.
    Examine the coolant for rust scale debris.
    This will give you an idea as to whether rust scale is sluffing into the coolant.
    Re-install the H/E.
    Filter the coolant, and re-install it.
    After another XX hours amount of run time, repeat the process.
    You should eventually see a reduction in the amount of rust scale debris.
    At some point, new fresh coolant could be installed.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  5. #5
    Thanks will take that on-board make god sense!
  6. #6
    I have an old Eaton Marine closed cooling system off of an FE Interceptor engine with all the plumbing, no pump though. Worked off the raw water pump and a recirculating pump... This is not the typical clunky system found on Chris Craft engines. I posted it for sale on the forum.
  7. #7
    Hi Thanks, have resolved heat exchanger going with a Savage engineering system bolts pretty much straight on! needed to change raw pump (Couldn't find parts for mine) to a crank pump , timing cover and installed circulation pump.
  8. #8
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,709
    Quote Originally Posted by grant1266 View Post
    You won't be disappointed with the crankshaft pump. Good call!
    Portland, Oregon
  9. #9
    Hi Rick, hopefully right call, still quite away before I get the boat back in the water and still trying to sort out pulleys to make sure it fits, the one on the motor was too small!
  10. #10
    I am looking at adding a fresh water cooling system to my 1960 312 as well. It has been used in salt water a bit. We are breaking the engine down now and it shows very little rust/pitting. It will be completely cleaned and freshened up. What is the issue with adding a closed system to a salt water boat? Does anyone know who/where I can find one?
    Thanks,
    Karl
  11. #11
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,101
    The issue is the engine's coolant passages will collect a lot of the debris and precipitate over time.....if you are rebuilding the engine, hot tank the block and find the passages clean, you are probably ok adding the closed system......
    I have no clue where to find a complete system.....piecing one together wouldn't be hard, just time consuming collecting all the pieces....
  12. #12
    Thanks!
Similar Threads
  1. Closed cooling
    By cyana in forum Marine Power Engine Forum
    Last Post: 06-06-2014, 07:53 AM
  2. closed cooling question
    By zackie77 in forum Mercruiser Sterndrive Forum
    Last Post: 03-29-2012, 09:25 PM
  3. Closed Cooling
    By paul_rodgers in forum Mercruiser Sterndrive Forum
    Last Post: 03-10-2010, 08:42 AM
  4. Raw or closed cooling
    By oil_slick in forum OMC Sterndrive and Inboard Archive
    Last Post: 03-26-2008, 05:45 PM
  5. Closed cooling system
    By rcaponeg in forum Mercruiser Sterndrive Archive
    Last Post: 05-31-2007, 01:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
