jokers_toys
start off info. 1974 Johnson 70h (70esl74m) on a 1975ish 16.8 ft Caravelle bow rider tri-hull.
just traded for the boat around first of the year have run it about 6-7 times with the family it has always ran great. At WOT about 31(GPS)
the problems....
time before last when running around ran great for 30 or so min running WOT it just slows down no shacking or cutting off just low rpm's. did this about 2-3 more times went home and changed the plugs they looked nasty took it back out the other day and started doing the same thing except this time it would not come off at most mid rpm range no high.
so now i put a tub under it started her up disconnect the fuel line to run all gas out (going to change the gas and line with new filter and bulb) but when the motor finely stopped it was very hot (3 sec touch at most) messed with a few wire and the alarm went off. (hot)
ok where am i guys should i just replace the water pump and t-stat then go try it out? i can check compression this weekend if needed. but the thing starts and runs so good Till......
thanks...........................
the problems....
