I have a Johnson 85ESL73M that's very hard to start when it's cold. New coils, plugs, wires. Carbs are immaculate. It has 135 compression on all four. Strong, consistent 7/16 spark, and good fuel delivery... it should run like it's hair's on fire. And it does AFTER a lot of cranking.
I've done all the usual... all new fuel lines, new bulb, new gas, soaked carbs overnight then sprayed passages and used a thin wire to pick at them, core plugs included.
I've read that once the green goo starts oozing from the stator then the spark is not as strong. That doesn't seem like my issue. Does it sound like it could be? After the initial cold start it runs great and starts quick the rest of the day. Will take any ideas, I'm at a loss. I haven't replaced the pack. Everything else is new so does this sound like a stator or power pack issue?
