Hi, I have a 1982 Renken 19ft with merc 120 4 cyl sn on motor 6155985, model MCM 120 153 cid
boat was running fine then stalled out and would not restart,called friend he put his boat in and pulled us back to dock.
since then I got new circuit breaker, rebuilt carb, put electric fuel pump, new points cap wires plugs cond, new coil.
it sometimes tries to start, has 135 pounds comp in all 4 cyls,
when trying to start and i put my hand over carb I do not feel vacum,
could it be i have a intake manifold leak? and that is why i can not get it to run? even with starting fluid?
Because as much I tried starting the plugs are still dry?
but I have no water in oil or cyl?
Thank you
John
Thank you
John
