Dave Sharkey
Need some help. I have a 1982 15 horse Johnson that runs, but when I accereralte it stalls. The model number is J15RCNC. I thought it might be the prop. My thinking was maybe it hit a rock or something and broke the pin. But I found out it doesn't have a pin. I'm thinking there is some other part that protects the propeller shaft when this happens. I can't seem to find out what that is. I've looked in the repair maunal and it seems like it might be a thrust washer but I'm not sure. I don't even know what the thrust washer is for. I have done a compression check and one cylinder is 60psi and the other one is 70psi. I don't know if this is good or bad. I also checked the spark plugs, they look good to me. I have determined that there is a spark on both cylinders that jump a gap of 5/16". I tested the maunal fuel pump when the engine is running it doesn't change the performance of the engine, don't know if this is good or bad either. I don't know where to turn next. Any suggestions would be appreciated.
