Results 1 to 1 of 1
  1. #1
    Default 7hp Sea king Montgomary Ward Clinton Air Cooled
    Model k700 3107a
    serial 925246
    type # 602737R
    Clinton Engine
    Any Help and suggestions are sincerely appreciated.
    1. I see that the Spark plugs suggested are Cj8 and Cj14, but also not clear as to what the Gap should be. I think I found .03, please correct me if I'm wrong.
    2. I keep seeing different comments on the suggested oil mixture on this, can someone guide me to the correct mixture for my motor or where can I look? Currently I have a 50:1 mix.
    3. My main concern is that it does not seem to be running at its full potential. It takes some real patience to start it, sometimes within a few pulls, sometimes more with some swearing. When running, its rather touchy, it seems the throttle screw moves and the handle has to be in the perfect spot (Just between the start and shift position). Ive also had it die on me while running across the lake, it bog's down and then I cant get it to throttle back to save it from dieing. With that said, it runs decent when working, but is real temperamental.
    If I missed any details that would help, please don't hesitate to ask.
Similar Threads
  1. 7 HP Montgomery Ward Clinton
    By fuzzy in forum Clinton Outboards
    Last Post: 04-28-2015, 03:57 AM
  2. Montgomery Ward Sea King 1973 5 HP Clinton K500
    By technoid in forum Montgomery Wards Sea King
    Last Post: 10-02-2009, 06:10 AM
  3. CLINTON IGNITION PROBLEMS 75 HP Sea King Montgomery Ward
    By bobbyg in forum Clinton Outboards
    Last Post: 06-25-2009, 11:15 PM
  4. Montgomery Ward Clinton Outboard
    By sdhardesty in forum Archive 2003-2009
    Last Post: 04-19-2008, 08:54 AM
  5. Montgomery Ward Seaking 75 HP Clinton Engine Help
    By jhnyutah in forum Archive 2003-2009
    Last Post: 03-31-2008, 12:07 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
