C
Colin Thomson
Guest
" Wonder if someone can help.
" Wonder if someone can help. Think I have identified the problem, Cyl 3 doesn't fire until engine is run up to max rpm. Ignition and carb OK but unburnt fuel shows on water surface at the stern when idling.
Assuming I'm correct and the bottom end seal is leaking the charge away, are there any special tools required to strip down to, remove and replace the seal? or can I get at it with normal sockets etc? "
