Results 1 to 3 of 3
  1. #1
    Default 1997 225HP Mercury outboard dies off after 10 min # 4000RPM
    I have two 225 HP 1997 Mercury outboards, carbs. One will run 10 min @ 4000 RPM and then dies off slowly, then after rest for 15 min, will run again. Did that 5 times in a row in short succession. I have done the following: vacuum checked fuel lines including primer bulb back to tank; changed both fuel filters (canister and on top of carb); rebuilt the fuel pump, have 4 PSI @ carb @ idle; replaced the ignition switch; swapped ECM's, heat checked the crank position sensor and ignition coils; changed plugs; ohm checked the throttle position sensor; compression checked all 6 @ 135psi. Have not yet torn down the carbs. Runs in driveway for 1 hr no problems. Out of ideas, help!
  2. #2
    Join Date
    May 2013
    Default Re: 1997 225HP Mercury outboard dies off after 10 min # 4000RPM
    Driveway running may point to fuel problems not ignition as ignition really doesn't know you are not under load but more fuel is required under load so that could be your smoking gun. Do you have priming squeeze bulbs on both engines? Are they fed from a common tank with Y fuel lines or something of the sort? When the engine dies, is the bulb sucked flat?
    If the bulb is sucked flat on the failing engine yet soft and round on the good one it suggests that the failing engine is suffering from fuel starvation from the tank, aka restriction in the fuel line or tank vent not venting.
    My 2c,
  3. #3
    check that your exhaust isn't partially plugged
Similar Threads
  1. 1972 Mercury 85 HP Outboard: Loses fuel pressure and dies
    By rasmus07 in forum Mercury Mariner Outboard Forum
    Last Post: 07-01-2012, 09:00 PM
  2. 1997 25 hp Mercury outboard Question
    By randyjarrett in forum Mercury Mariner Outboard Forum
    Last Post: 06-26-2011, 09:07 PM
  3. Mercury 225HP Outboard (2000 EFI) Fuel Problem
    By Brandon Valley in forum Mercury Mariner Outboard Forum
    Last Post: 01-30-2011, 04:40 AM
  4. '1997 Volvo 4.3 I/O dies runs fine, but dies.
    By trebor-75 in forum Volvo Penta Gas Engine Forum
    Last Post: 08-16-2010, 10:31 AM
  5. 1994 Yamaha 225hp TXRS dies out at 4000rpm
    By rabrador in forum Yamaha Outboard Forum
    Last Post: 06-24-2010, 09:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
