Janine N Robert
I have tested eveything I can think of and I am at a lost. My motor works fine as I have tested it by put wires directly to battery. Then I tested motor by jumping the wiring harness prior to the relays. I also removed the relays and tested them. I put power to relay and I hearing a clicking and both seem to work but once I connected everything still trim motor doesnt work. So then I tried to test the switch by trottle but I could not get motor to work still when I bypassed the switch. I have to think its my relays but not 100 percent sure as everything I have tried works. Anything else I should try prior to buying new relays.
