Click for Volvo Penta parts and manuals!
Results 1 to 4 of 4
  1. #1
    Default trim not going up
    1st post. Just bought a boat w a 2002 8.1l Volvo. The trim switch was working well then at the end of the day when I tried to trim I up it was just making a clicking sound. Trim down works fine. This is the switch on top of the throttle.
    Thanks Joe
  2. #2
    Default Re: trim not going up
    I note that no one responded to your first post and I hope you were able to solve the problem. I had the same problem with my boat. If you're still having problems with your trim - it may not be the switch but the relays on the pump itself. Pull them both, take them to an auto parts store (they're standard and a heck of a lot cheaper than the Volvo parts) and replace them both. Should cost you about $20.
  3. #3
    Haha, been a while. I replaced the relays and it worked fine for a while then happened again. Turns out the module that the relays go into was cracked so I replaced that and solved it I was Mickey Mouse repair prior but now a new module/harness. Thanks, Joe
  4. #4
    Join Date
    Jun 2008
    Location
    Island Heights, NJ,
    Posts
    2,646
    Thanks for getting back to the forum with your fix. Have a good rest of the season..
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    1972 22ft Bristol
    Honda 7.5HP 4 stroke Long shaft
Similar Threads
  1. 1989 Johnson 110 - Trim/Tilt working Out of Sync, Trim cylinders "squeak" ?
    By leaky in forum Johnson Evinrude Outboard Forum
    Last Post: 01-05-2014, 03:18 PM
  2. E225TXCDA 1986 225 Evinirude won't trim down but will trim up
    By chessbass in forum Johnson Evinrude Outboard Forum
    Last Post: 10-26-2013, 06:54 PM
  3. Convert trim assist to power trim.
    By JimBob25 in forum Honda Outboard Forum
    Last Post: 07-24-2012, 12:09 AM
  4. Power trim slows engine down when trying to trim?
    By LGnBAMA in forum Mercruiser Sterndrive Forum
    Last Post: 07-17-2012, 12:58 AM
  5. Mercruiser 120 how to bypass the trim limit and trim position sensors
    By Dan Moriarty in forum Mercruiser Sterndrive Archive
    Last Post: 08-19-2006, 12:34 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
