I should elaborate from my original post. I have been trying to get the boat running for a few weeks now . When I first brought the sea ray home from long term storage(around 7 years) by my late father it had cream in the oil. I was concerned about a cracked block at first. I change oil twice and got all the water out then proceeded to start it up. She ran on starting fluid for a few minutes at a time. It would not idle on its own with out constant spray of starting fluid. It was enough to get it up to temp. 145 approximately. The oil stayed clean and dry so far. I was recommended that I put seafoam in the carb. I let it soak for two days and charged the battery up. When I tried to start it this time it had a bad knock in the engine that was not present previously. Could the seafoam have damaged the engine. Could I have gotten the timing off by the repeated cranking. Or could there be a bent rod or worse. I want to get some advise before I start it up again.
