Hello to the forum,
I'm just repairing the lower unit of my DT200 (the torpedo tube was cracked and the nut got loosened). I have now welded the housing, dry-fitted the bearing housing and fitted all new sealings, so basically the lower unit is ready to be built again. Except for gear clutch. Two questions:
1. I bought the sealing kit for lower unit, but my kit doesn't have the shaft seal/scraper that goes to top of the clutch housing. Should it be in that kit? Also those o-rings might be gone too.
2. How do you open this thing? It seems to have at least two springs in it and based on how stiff the system is, those springs have original juice still in them. So I am afraid if/when i get this thing open, I'll not going see those springs and balls anymore, ever...
Capt Djob
PS. Does the system have three or two stage action/stroke? When using by hand, I only get it to move in two positions so I was wondering if the neutral is in the middle of these stages. Or are there three distinct "stages" for forward, neutral and reverse?
Capt Djob
