Hey everyone, I'm new to the forum and have little knowledge about my outboard but learning quick about it. I hate to over whelm you all, but I really need some help. To start I can't find the serial or model number anywhere. The tag sticker only says VOID, VOID, VOID. I think it's an 1989 because that's what's on the title. Here are my problems: It starts right up when launching off the trailer. After running to earthier the dock or fishing spot once I shut down, it has a hard time to restart ( motor warmed up or cold ). It takes several cranks and once it starts I have to quickly go to almost full throttle to keep it running. At full throttle it feels sluggish and doesn't feel 100% ( At times it runs great and at times it doesn't and the throttle is in the same position). I have had the boat for two years. It's a 20' Beachcomber Pontoon. When I bought it the compression was at 130-132 psi. and ran great. The carbs had been rebuilt (carb kit). This is what I have done so far: Change plugs, primer bulb(attwood from Wal-Mart), reset air fuel mix screw, reset carb throttle linkage for all three to be equal, checked timing, (Note on timing. I was checking it running. It was way off. I have seen videos and read up on the timing. I cannot get the timing into spec due to I run out of adjustment and the throttle tower shaft hits the gear shift arm also.) I do not have a tach on this motor. I'm not even sure this motor is for this boat. I do believe and feel that the motor stills has life and plenty of power. I'm just not sure how to go about adjusting everything such as throttle cables and timing. I also feel a misfire but I can't find it. I read about changing the spark plug wire end to automotive style instead of that spring style. Any info will be greatly appreciated. Thanks for helping. I use this boat in the DFW area. Lake Lewisville if that helps or means anything.
