Sean Flesch
Well I have a new to me 1988 Magna 17 tracker and the engine was running fine. I thought i'd do some PM so I replaced the plugs..still ran great.
Then I noticed gas on my hand from the bulb developing a small crack so I replaced the primer bulb and fuel line (it was in decent shape but it was 4 years old). At this same time I pulled off the "airbox" cover and cleaned the throttle bodies with seafoam deep creep. I also placed a inline fuel filter in the new gas line. I took it out and it starts fine and will high idle fine but when put into gear wont spool up and boggs at 2500-3000 rpm. I ran it back and forth across the lake this way with no change. shut it down, fished a spot for 2 hours, started it back up, took off, still bogging down but running smooth otherwise.
I took out the fuel filter thinking I was restricting too much and it made no difference. I was told by a outboard mechanic (unseen) that it sounded like I was sucking air somewhere. I checked and rechecked and tightened every connecton in the new fuel line. Still bogging down, runs fine at idle.
I am now thinking that I may have not put the "airbox" cap back on properly? That's the only other thing I touched. but the job of that box is to pull air isin't it? Seems like that would not be it if I lined up the screws and tightened them down. Any help would be appreciated as I am still paying for this and have little funds to take this to someone. I am open to all troubleshooting suggestions.
Sean
Sean
