hopefultooner
I,m working on a ns50c lower end. I,v pulled the prop and prop shaft and am looking inside the foot and there is a gear way back in there. this gear doesnt seem to want to move, spin orrr come out. any suggestions?
The LU houses 3 gears. The A gear (F), B gear (pinion) and C gear (R). When you pull the prop shaft housing (with Reverse gear), you will see those 2 remaining gears.
You need a service manual to fully see the setup, unless you are already familiar with lower units.
Why did you take it apart?
