Results 1 to 4 of 4
  1. #1
    Default Broken prop shaft
    I am a complete novice and took on rebuilding a 5 hp Ted Williams outboard that my grandfather gave me. After about a year of playing with it I finally got it running. However the prop had a crack in it and I decided to replace. The prop shaft was so old that while removing the prop, the shaft broke at the pin. I am completely at a lost at how to remove the broken shaft. Any suggestions would be GREATLY appreciated.
  2. #2
    Join Date
    Aug 2010
    Location
    Bank of the Ohio river
    Posts
    138
    Default Re: Broken prop shaft
    You see that on some models due to a bad Stainless Steel batch,I heard it was to much Nickel n the alloy, my OMC SST big boat prop gets surface rust and its polished SS, or it use to be.
    we need the sears model number should read "217-xxxxxx "
    once you find it look it up at Searspartsdirect, do not expect Sears to have anything an what they do have is way over priced, you will need a used prop shaft, seals and bearings are no big deal
  3. #3
    The model number is 217-59430 ..... I can get a prop shaft off of ebay, however I can not get the broken out? Anyone have any suggestions on how to remove the broken prop shaft from this model?
  4. #4
    Join Date
    Aug 2010
    Location
    Posts
    138
    One thing I see in the manual that is common to the forward only Eska lower that will have to be removed,, there is a pin holding the drive gear that has to come out... this may be the only thing holding the shaft in,, but also there is a snap ring on the pinion,, I don't recall having to remove the snap ring on this model like we do on the F-N-R models, but I'm sure the forward gear roll pin must come out to free the shaft.
Similar Threads
  1. Mercury 2012 60hp 4 stroke. Broken prop shaft. Non Bigfoot. 67 hours use.
    By Neil Mitchell in forum Mercury Mariner Outboard Forum
    Last Post: 03-11-2013, 04:06 PM
  2. Mariner 9.9ML 682C 361494 (Lower unit Shift Shaft Broken/Issue in prop gearbox)
    By kenlodato in forum Mercury Mariner Outboard Forum
    Last Post: 12-11-2012, 08:56 AM
  3. Yamaha 9.9 2 stroke long shaft engine - crank shaft bearing broken up
    By Julianadam in forum Yamaha Outboard Forum
    Last Post: 12-06-2012, 07:34 AM
  4. Broken shaft
    By las64 in forum Nissan Tohatsu Outboard Forum
    Last Post: 03-07-2009, 03:39 PM
  5. Broken drive shaft 25 hp omc
    By mikee in forum Outboard motors archive 2000-2004
    Last Post: 07-30-2002, 08:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
