They are not the same part number and the latter model had two different clutches - so can't give you anything more than a "maybe".
In mid 1994 Merc made "some changes" to the majority of their model line. Many things stayed the same but enough changed that some items were no longer a "bolt on" replacement.
Both units used the same drive shaft, so that will "fit in" to the crank and I would assume that the bolt pattern will be the same, but I wouldn't want you relying on my word and having an item shipped at significant cost only to find that it is a touch different.
