I replaced my fuel pump with another one off of a similar 350 Crusader. Here's how it unfolded,
- Removed all the fittings from the old pump, noticed there is fuel in both lines (to carb and from tank)
- Put in the new pump, engine did not start
- Removed that pump, installed a different pump (exact replacement), noticed both lines were all dry
- Engine does not start, both lines dry
- Checked for clogged filter at carb, or anything obviously clogging at all the fittings, found nothing
This is my starboard engine running off the starboard tank. To rule out something related to the tank, I turned on my crossover valve and ran the port engine off the starboard tank for a while (with the port tank shut off). Runs fine.
So the only thing left is the line from the fuel/water separation filter, which is a 3/8 copper line with about 12" of flexible hose at the end, to the fuel pump. Seems very strange, if something were clogging it, seems like "some" fuel would get through but it's totally dry. Is it possible that the needle/seat is stuck in the carb, not allowing the pump to pump any fuel? I guess I will check the line next.
