I got 1987 Evinrude 30HP electric start motor. I purchased it used two years ago. Motor is very clean. Seller said that motor was sitting in his basement for few years, and when I started it (Summer time) it was running a little rough, but nothing too bad, compression was good, so I bought it. I dropped it of for the guy (retired mechanic) who worked on my 15Hp motor before to " bring it up to a speed ". He had rebuild the carburetor, replaced plug wires, plugs and cleaned/flushed a lower unit (did not look like oil was replaced in last 10 years, maybe longer) and external fuel line needed to be replaced as it sucked in air. Motor started and ran like a champ on muffs when I picked it up in August and I left it alone until duck season.
NOW THE QUESTION - pretty much every time I would start my motor (Sept-December), it would take 4-5 attempts to start it cold. When it starts, it keep coughing/ backfiring, running high revs on Neutral and then drop revs, chokes and dies or almost dies, then pick up revs again .... very annoying... Once it worms up for 5-7 minutes it starts working like a clock and keep working fine all day long even if you let it cool off for 3-4 hours, starts, it start right away, runs smooth, etc.
PLEASE HELP.
Thank you
PLEASE HELP.
Thank you
