welshswampy
Had a problem with the reverse latch mechanism on my early 90's 290 dp, ordered the 4 new springs and changed them ( one turned out to be snapped and the others appeared weak)
However, out fishing yesterday and the same problem reoccurred on entry to the outward lock (drive popped up in reverse)
As we were already out, we decided on a days fishing and to sort it our when we got back
So, whilst trying to dock (without much reverse and with a cross wind) I found I couldn't engage forward, but luckily enough I drifted near to an empty pontoon and moored there for the night
Went down this morning and found the whole reverse latch mechanism had spun on the shaft/pivot tube? managed to manually lift the leg and move the mechanism back central with a short bit of tube, tested it all and it now works fine
Any ideas why the mechanism is turning, as I see it, it should be held closed the whole time unless it takes a hit
Anyone have any pictures of their reverse mechanism so I can see how it should look
Also, the "plate" on the mechanism was buckled when I changed the springs, so I straightened it the best I could
Any pointers?
BTW, before I turned the mechanism back to centre, I disconnected the gear shift linkage and was able to manually put leg into forward and reverse smoothly, it appeared that somehow the spun reverse latch was stopping the selector arm from engaging forward
Hope this makes sense to some of you
Any pointers?
