Hello. I have a 97 yamaha pro v 200 horse. I was wondering if its normal for this motor to bog a little at lower rpm. When you get on it there is almost a lag at low rpm and if you let off the throttle to come to a stop and try and get back on it again there's quite of bit of bogging. Also what is the max rpm I should be getting out of them motor? It has a 4 blade ss prop otherwise it is stock as far as I know. Im getting about 5200-5300 rpm at full throttle.
Thank you so much for your help.
