BF30A engine oil
taymag
I have a BF30A and I have 10w-30 oil... I see in the manual it says 5w-30 for the BF30. Can I use the 10w? I am in Florida and usually only boat in 75+ degree weather if that info is needed. Thanks!
At that temperature the 10w-30 is probably ok. Only use the mineral base oil not semi synthetic or full synthetic....unless you have hundreds of hours on the motor.
Mike
