hello, I have a 75hp 4 cylinder 1986 Mercury that is not sparking on the bottom 2 cylinders. I was idling the engine last week and suddenly the motor went dead. A quick check found the problem. I have a maunal on order but I'd like to quickly fix the problem.
I checked the stator and resistance is in the correct ranges with no ground showing. I swapped the stator leads also and my problem remained the same(bottom plugs no spark.) With these checks I 'm assuming the stator is good, correct?
I understand that I can swap the trigger wires to check the trigger, but the searches I did do not have the same wire color wires from the trigger. My wires are; violet, white, brown, and white with a black stripe. My question is which wires do I swap to check the trigger.
I'm guessing that I have a faulty trigger box, but I replaced it last year and am wondering why it could have gone bad with maybe an hours running on the new box. Maybe a coil that isn't up to par?
Thanks for any help,
I
I
