Results 1 to 4 of 4
    Default Help identifying this 'knock' on a 1965 CC 283
    Here's a link to a YouTube video - you can clearly hear the knock.
    https://www.youtube.com/watch?v=OnUS...ature=youtu.be
    The knock is intermittent, both in that it doesn't occur every revolution when the engine is running, nor does it occur every time I run the engine, so I'm pretty sure it's not a spun bearing. The sound 'seems' to be coming from the forward left side of the engine.
    I have checked the flywheel - solid - and all the flywheel bolts - tight.
    I have checked that the starter is solidly bolted on and not moving.
    I removed the valve covers and ran the engine. All valves are operating as they should, all with the right amount of travel.
    I've looked inside each cylinder with an inspection cam, no loose objects, none of the spark plugs were damaged.
    I've removed the intake manifold and looked inside each intake port. No loose object, no apparent damage to the valves or sign that anything has been rattling around.
    I removed the inspection plate on the side of the oil pan. No loose objects or metal chips/shavings in the bottom of the oil pan. Both a magnet and a clean rag came out with no 'gritty' stuff.
    I removed the oil filter and cut it open. No metal bits in their either.
    Anyone got any other ideas? Pulling the engine is a last option because it's a hard top boat and I can't get a crane over the engine hatch.
    Richard
    Default Re: Help identifying this 'knock' on a 1965 CC 283
    Of all the strange things, it turned out to be a loose motor mount.
    OMG! Really? Glad you got it fixed! Thanks for letting us know
    My Motto Is:
    K.I.S.S.- Keep It Simple Stupid!
    Or, It Might Get Real Expensive!
    May 2016
    Alcoa, TN
    2
    Mine does the exact same thing. Thanks! I'll check the mount next time I'm on board.
  1. knock-off nut
    By michelodeon in forum Chrysler Force Outboard Forum
    Last Post: 06-13-2012, 09:53 PM
  2. engine knock
    By reb in forum Mercruiser Sterndrive Forum
    Last Post: 06-02-2010, 08:58 PM
  3. 290 DPA 1990 Knock
    By skiss in forum Volvo Penta Gas Engine Forum
    Last Post: 11-16-2009, 10:29 AM
  4. Mercruiser 470 Knock
    By cobraman428 in forum Mercruiser Sterndrive Archive
    Last Post: 08-20-2009, 11:15 PM
  5. 225 VRO Knock Knock 1996
    By onthewater1 in forum Johnson Evinrude Outboard Archive
    Last Post: 10-02-2008, 05:26 PM
