I picked up a Honda B100-1203497. I have it in a barrel with new gas. At first I can only get it to start if I use starting fluid. The motor has to be full choked and once started has to be full choked and high idle. Even at that it will only run for 20-30 seconds and then dies out. If I try to slowly push the choke in it will die or if I reduce the throttle it will die. I did pull the carb and shot carb cleaner all inside. Since then it does start a little easier but still does the same thing and will not idle. Any help would be appreciated on what to try first in getting this motor ready for this summer.
Thanks in advance,
Jeff
Thanks in advance,
Jeff
