lakehartwellguy
I have a problem with a 2003 model BF50 - cylinder #2 misses at idle, runs ok at higher rpm. I've drained the carb for that cylinder, changed plugs, pulled #1 & #3 out, leaving #2 in, felt the compression when turning flywheel.
I pulled the rack with the 3 coils - measured resistances - all the primaries are the same, about .5 ohms - measuring from the spark plug caps to the ground terminal, #1 & #3 measure about 14 k ohms, #2 measures 12.45 k ohms. Does the coil sound like my problem?
