Gentlemen I need your help
My 318 Strd eng has seized. I believe to Hydrolock
The Eng began to run very rough and would not idle. I checked the Points and they were the worst I have ever seen
It is at this time I had to go out of town for a month.
Upon my return I changed the Points and while cranking the engine over to set the gap it seized
I checked the Spark Plugs and found water and rust sludge in Clylinders 2 - 4 Pull the Exh Manifold and found lots of water - mainly 2 - 4
Pull the Clylinder Head and lots of sludge in - 2 - 4. Checked the Clylinder Head gasket and it looked ok
This all started in early September so I do not suspect any Cracked Eng components
Pulled the Intake Manifold and inspected the Metal Gasket - seemed ok No water in the oil
I dont believe that the Exhaust System is at fault If there was, water would have maide its way into Cylinders 6 - 8
I suspect the Intake Maifold Gasket - Any thoughts
