johnbatman520
Hi. Hope you can help. I have a 1987 mercury 70hp 3 cyl 2 stroke. Last year while on the water It just died on me and I discovered it had no spark. I didnt do anything with it until recently when I bought a donor 1987 Mariner 75hp 3cyl 2 stroke for parts. I swapped the stator and trigger and still had no spark, I then swapped the switchbox and got spark back. I now have the stator, trigger and switchbox from the donor engine on mine. I fired it up today and it started immediately. I brought it out for a spin and it took off like a scalded cat! When I came back to the harbour and put it into neutral I noticed it was idling very bad. It's popping a bit and seems to be revving up erratically. I brought it for a spin again and it seemed fine but when back in neutral the bad idling continued. Some additional info... I was afraid the auto lube might be blocked due to sitting for almost a year so I mixed 2stroke oil at 50:1 in the fuel tank incase the autolube wouldnt work... Also after a couple of minutes on the water I noticed the tilt and trim wouldnt work so I checked the battery and the positive lead had come loose, I re-attached it and continued on my test drive. I just wondering could this erratic idling be caused by gunk in the carbs or xould it be something to do with the replacement electrical parts? And help would be much appreciated. Thanks in advance, John.
