Toadfish88
My 09 BF60 has been sitting for about 5 mo., I pulled it out yesterday to clean it up and run it for a while. Engine cranks over fine but has no pressure going to injectors, I can not get fuel pump to run. Batteries have full charge and fuses are good. Fuel pump fuse is getting power with key switched on, I'll try to verify voltage tomorrow if I can find my tester. I'm sure no one else has trouble with misplaced test equipment like me, LOL, my wife calls it sometimers disease! I want to apply full 12v to pump just to see if it will run before proceeding. If I can unplug wiring harness from the relay, does anyone know what color wires I could use to power pump from that location? Otherwise it looks like I'll have to disassemble the intake in order to reach where the harness plugs into the pump assembly. If pump will run that way I will proceed with testing voltages at different locations and checking relay. Does anyone know procedure for checking relay? If anyone has a wiring diagram with with wire colors that would be very helpful. Any help will be greatly appreciated as cookie jar funds are running low!
