Hi,
Does anyone can give me more detailed specifications about raw water pump for this engine (rated at 195HP/3000RPM). I found out on the internet, that original raw water pump for V-504 was Jabsco 11600 (impeller pump). I am not sure, but I found some info that mentioned this pump flow rate was 80 LPM (liters per minute), but I am not sure. Anyway, even if that is correct, does anyone know at what RPM is that specification given? At what engine RPM should be max flow rate defined? I found on some older engine datasheets (V-504) following statement:
"Minimum Raw Water flow with Water tempratures to 90F (32C) ......32US GPM (2.0liters/second)"
Now, this line is a bit confusing to me, since this temperature is very low and I do not know on which exactly temperature is this line referring. Also, is that flow rate supposed at maximum RPM, or at highest torque RPM, or...?
Anyway, I have a Gilkes raw water pump (circular pump), which in my personal opinion is better choice for raw water pump. Thing is, that I do not have a pulley and I do not know the flow rate of this pump either. So I plan to test this Gilkes pump I have and find out the flow rates at given RPM. Then I need original engine pump data, so I can design the correct pulley.
Yes, this is a bit complicated, but since my engine is new, never used, so as this Gilkes pump, it does pay off to me. For the pump, I contacted the Gilkes, but no answer yet, probably due to old type numbers, but if they cannot help, I will test it by myself for needed data (flow rates at specific RPMs and make a curve).
I would appreciate very much if someone can help me here with these information.
Best regards,
Nikola
Best regards,
Nikola
