Remove the lower unit.
Put the lower unit into reverse gear by depressing down on the shift cam assembly.
Put the shift control lever into reverse.
Run the jam nut down on the lower unit shift cam assembly threads as low as it will go.
Run the coupling nut up on the shift rod threads as far as it will go.
Reinstall the lower unit onto the mid-section.
Run the coupling nut down so that it engages both the shift cam assembly threads and the shift rod threads equally.
While holding the coupling nut to prevent it from turning, run the jam nut up until it interfaces securely with the coupling nut.
Shift the lower unit into neutral. Start the motor and make sure that it shifts into and out of all gears and neutral.
