Results 1 to 4 of 4
  1. #1
    Question 83 sailboat with Yanmar 18 hp.
    The engine died and would not crank. Replace fuel filter. Fuel is not coming from the tank. This model does not have a manual pump on top of filter. Any ideas on how to narrow down the problem. Engine has been great for nearly 20 years.
  2. #2
    Join Date
    Feb 2014
    Location
    Kitchener Ontario
    Posts
    19
    Default Re: 83 sailboat with Yanmar 18 hp.
    Quote Originally Posted by Sweeney View Post
    Sounds as if you have a 2GM or 20 or 20 F Your fuel feed pump on the side of the engine will have a lever you can thumb push up and down, if you do not feel any resistance turn the engine one turn as the cam that runs the pump may be at its max travel and will not activate the fuel pumps diaphram when you pump the thumb lever. Does the engine tunr over at all when you hit the starter to start?
    Bleed the fuel system and change the fuel filters if you have not done that in a while. Oh make sure you have fuel.
    Happy sailing
  3. #3
    Quote Originally Posted by Capt'n Squid View Post
    Happy sailing
    It's an 18 hp. Engine turns over great. I will try your suggestion. I replaced the filter yesterday. Thanks for quick response.
  4. #4
    Join Date
    Feb 2014
    Location
    Kitchener Ontario
    Posts
    19
    There always is a pre- filter. That is a fuel/ water separator between your fuel supply and engine. Check that one also. When bleeding the system ie no air in fuel lines then try to start it.
    The valves should be adjusted to .008 both cold.
    Invest is a work shop manual, it had a lot of pictures and is a good buy and read for the layman. Enjoy..
Similar Threads
  1. F2.5 on a sailboat....stalls out
    By whitegreg56 in forum Yamaha Outboard Forum
    Last Post: 02-26-2014, 07:29 PM
  2. Outboard on Large Sailboat
    By maisso in forum Yamaha Outboard Forum
    Last Post: 04-11-2010, 03:23 AM
  3. Domestic Hot Water in a Sailboat
    By fatfenders in forum Miscellaneous marine engine topics
    Last Post: 06-12-2008, 10:18 PM
  4. Hydrostatic Drive for 24b Sailboat
    By dickindvn in forum Archive 2003-2007
    Last Post: 04-08-2006, 09:07 PM
  5. Diesel conversion for sailboat
    By eddie in forum Other Diesels Mfgs and General Diesel Questions
    Last Post: 03-06-2006, 09:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
