Click for Chrysler parts and manuals!
Results 1 to 21 of 21
  1. #1
    Default Starter for 318 chrysler engine
    I have a 1971 penn yan inboard with a 318 Chrysler engine, and I need a starter for it. My problem is that I don't know the year of the engine.The starter does not have a cylinoid on it.It's a two bolt mount, 12 1/2 inches long, with one elec. post on it. I'm pretty sure the engine is in the 1970's region, and would like to know if the starters are basically the same for that period.And if anybody out there would have one? I would sure appreciate some input.
  2. #2
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,606
    Default Re: Starter for 318 chrysler engine
    If no solenoid, it's an old Bendix drive motor.
    Treat your engine to a HTGR/PMGR motor, and enjoy better starts with less Amp draw!
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  3. #3
    Rick,
    Where can I get one, and how much are they?
  4. #4
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,606
    Chrysler pioneered the automotive gear reduction starter motor!
    Most Marine starter motors that you'll find these days (as OEM equipment), will be high torque gear reduction/permanent magnet gear reduction!
    Whether I/O or I/B!
    Portland, Oregon
  5. #5
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,439
    You can get it rebuilt. SHip it to this guy and he'll make it brand new (and for a reasonable price). Dealt with him several times with complete satisfaction.
    Park Manor Sales and Service
    915 Greenleaf St. (near 9th)
    Allentown, PA 18102-1473
    610-770-9488
    Jeff
  6. #6
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,606
    Quote Originally Posted by fastjeff View Post
    And at the end of the day....... he'll still have an outdated Bendix drive non-reduction starter motor!
    Portland, Oregon
  7. #7
    Join Date
    Sep 2003
    Location
    Posts
    15,439
    Yeah, but it'll work great, s mine has for 6 years now.
    Jeff
  8. #8
    Join Date
    Mar 2008
    Location
    Bruford SC , U.S.A.
    Posts
    325
    Unlikely to get OEM quality gear reduction for a Chrysler since there weren't any......
    Jack
  9. #9
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,606
    Quote Originally Posted by 300hb View Post
    Jack
    Not so.
    Portland, Oregon
  10. #10
    Join Date
    Nov 2005
    Location
    Chi West, IL, USA
    Posts
    770
  11. #11
    Join Date
    Nov 2008
    Location
    Long Beach, CA
    Posts
    215
    I had mune rebuilt it works fine. Yes a Gear reduction starter would be nice but unnecessary. I also dont know of a sours for a BOLT IN no modification gear reduction starter that works with these chryslers.
  12. #12
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,606
    A non-gear reduction Bendex style starter motor relies on quick/fast torque to kick the Bendex drive pinion gear into the flywheel ring gear.
    Should we encounter a week cranking battery, often the Bendix motors will not engage.
    The Bendix motor engine cranking RPM is limited to the pinion gear/ring gear reduction, and the Armature RPM.
    Conversely, a HTGR/PMGR motor armature spins approximately 3x's faster, and via the reduction, spins the engine crankshaft at a slightly higher rpm!
    This usually results in faster starts, and less battery Amp draw.
    As said earlier, the Chrysler company pioneered the V8 gear reduction starter motor, and did so in the 1950's.
    Your call........ But I'd certainly suggest the HTGR/PMGR motor.
    Portland, Oregon
  13. #13
    Join Date
    Nov 2008
    Location
    Long Beach, CA
    Posts
    215
    as stated. I am not aware of a bolt in marine HTGR/PMGR starter for our chrysler inboard applications. I know there is one for the chrysler/volvo I/O applications. If you know of one, I would be happy to see it and maybe even try it.
    will
  14. #14
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,606
    Quote Originally Posted by buick430 View Post
    as stated. I am not aware of a bolt in marine HTGR/PMGR starter for our Chrysler inboard applications. I know there is one for the chrysler/volvo I/O applications. If you know of one, I would be happy to see it and maybe even try it.
    will
    Will, I believe that these have been around for years.
    http://m.rakuten.com/product/2347322...ngID=229833535
    In post #15 here, I show a second style forward facing inboard HTGR starter motor
    http://www.marineengine.com/boat-for...nboard-Starter
    The Chrysler Inboard will be using the forward facing style motor...... Correct?
    I.E., the style motor that bolts on from behind the flywheel....... typically to the Borg Warner flywheel cover.
    http://m.ebay.com/itm?itemId=331003189317
    Portland, Oregon
  15. #15
    Join Date
    Nov 2008
    Location
    Long Beach, CA
    Posts
    215
    It looks like those would bolt on. Have you ever ordered from rakuten?? Ive never heard of or seen that starter before. I honestly think I will just keep my old fashioned bendix starters.
    will
  16. #16
    Join Date
    Mar 2008
    Location
    Bruford SC , U.S.A.
    Posts
    325
    Quote Originally Posted by daves69 View Post
    Cool....., can't believe they weren't snatched up (Jeff).
    I'm assuming the other is an import
    Jack
  17. #17
    Join Date
    Oct 2012
    Location
    Long Point Beach Ontario
    Posts
    80
    Hi
    i have been using these high speed starters for years. I could not find a good side view but here is a shot that shows it from the front on a 383 I sent to Sweden. These work great. Contact Rare Electrical in Florida, that's where I get them. They have them in both rotations. These will use the original 172 tooth ring gear that was on these old engines. the ring gear is available from Auto Zone, just look up a 1965 Plymouth with a standard trans. they are about $25
    not worth screwing with those old 1958 starters any more.
  18. #18
    Join Date
    Oct 2012
    Location
    Posts
    80
    heres the pic
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	Copy of 101_1893.jpg
ID:	9132   Click image for larger version.
Name:	assembly 20 low resolution.jpg
  19. #19
    Join Date
    May 2013
    Location
    Western Wahington
    Posts
    48
    Just my 2 cents worth.... I've had the direct drive starters on my twin LM318's for the last twenty years. Never liked them. I rebuild my own and even after OH they take a lot of juice to crank the motors. I'm going with Rick's advice on this one and converting to HTGR. Found this web site for Chrysler Inboards.
    http://mascostartersandalternators.c...duct_list&c=40
    I'll let you know how they work!
  20. #20
    take it out and bring it to a good marine shop they will know
  21. #21
    Join Date
    Jun 2013
    Location
    Western NY
    Posts
    67
    I had mine rebuilt 3 years ago, now it starts at a touch of the key, more than satisfied. It definitely draws less amps than before the rebuild. Do it!
Similar Threads
  1. 1972 Chrysler 55 hp starter
    By ahalverson in forum Chrysler Force Outboard Forum
    Last Post: 07-07-2012, 02:42 PM
  2. Chrysler 265 starter mptor
    By gryg1 in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 01-04-2007, 12:46 AM
  3. Chrysler 265 6 cylinder motor starter
    Last Post: 12-30-2006, 08:33 AM
  4. 65 HP Chrysler Starter Solenoid
    By dcrawley in forum Chrysler Force Outboard Archive
    Last Post: 12-15-2006, 07:36 PM
  5. Starter troubles Chrysler
    By MIKEPAUL in forum Outboard motors archive 2000-2004
    Last Post: 06-14-2002, 10:20 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
