Stephen Hurst
Any help is appreciated. I've hit a brick wall. The starboard runs fine so I've swapped the following parts for comparison:
ECM
Coil (in case it was weak spark)
Cap and rotor
Installed a new battery as the starting battery on the port side was bad. Removed a valve cover to verify valves were opening and closing. Fuel pressure is 46psi. Removed fuel rail to verify spray pattern and operation. Sprayed with starting fluid and it won't even cough.
What should cranking speed be and would slow cranking effect the engine not even trying to start?
Could it have jumped time and if so is there a way to check without removing the front cover?
Please help, I'm out of answers
ECM
Cap and rotor
