My motor is a 1984 "tower of power" inline 6. It appears that #6 cylinder is not getting fuel as the spark plug looks brand new. Cylinder #5 which shares the carb with #6 looks like all the other plugs with normal amount of gas/oil on them. The carb for #5/#6 does not have separate jets for each cylinder. #6 has lots of spark and the compression is the same as the other 5 holes (140). I just bought the motor and have had only one short test run so I have no history to share with you. Where should I go from here?
