floatin radio
I once had a gas leak and I couldn't figure out if it was the tank of filler hose (both under the floor) I hAd access to the filler hose at the tank, I put 3/4 of an ounce of yellow food coloring in 20 gallons of gas to see if would show up In The bilge. No yellow gas showed up anywhere. Motor was running very rough, my buddy was looking at carb when I pushed throttle and he said "did you pee in your gas, why is it so yellow?"
We ran boat off aux tank for the day. Had to drain gas tank. Found the leak when I filled up the boat. Filler hose had a 8" long hole in it. When I filled up my boat with gas, I literally filled my boat up with gas! Surprised I don't blow my self up! Pain to replace, 6 feet routed under floor.
Moral of the story, even though my food color idea made sense in theory, sugar in the gas tank was a bad idea!
thanks for following up with your process
