Sure could be. Grab a #3 phillips and pull the pump. Reconnect it to the gas line, and prime the bulb. You will likely see tons of gas coming out at the push rod. If so, and you feel capable, you can change 3H6040050M DIAPHRAGM $27.60, or replace the 3H6040007M FUEL PUMP, 4/5/6/8/9.8 4-STR ONLY $60.83. Because of labor costs, in the shop, we usually just do the whole pump, as well as 3H6074220M O-RING $1.26. We do have parts on the shelf. Problem is that postage to the Bahamas will be pricey.... about $25.00 and 6-10 business days by USPS Priority Mail Small Flat Rate Box. Your other option for a dealer would be Company Master Marine & Cycle, Bay Street, PO Box AB20229, Ma Baham, Phone 242-367-4760.
In the future, be sure to disconnect the gas line at the end of the day to avoid over-pressurizing the fuel system from solar heat/expansion. Also, run the carb dry at the end of the day (unless you will be running again tomorrow), so you reduct carb varnishing.
