Results 1 to 3 of 3
  1. #1
    Default Exhaust leaking smoke and water...
    Hi everyone,
    I am new here. I've just bought a dutch barge in Holland and have this problem in the engine room.
    Would you recommend that I take the part off and weld it or look for a new part? If so, does anyone know what you would call this part?
    Any help would be massively appreciated.
    Thanks!
    Nathanael
ID:	8423Click image for larger version.
  2. #2
    Default Re: Exhaust leaking smoke and water...
    O, and it's a DAF 475!
    Cheers
  3. #3
    Hi nathanael,
    suggest removing the four bolts and take it to a good welding shop to make a new one this looks so bad it might be leaking water back into your engine when you shut down !!
    Charlie w
Similar Threads
  1. Water leaking from exhaust
    By ranmar1 in forum Johnson Evinrude Outboard Forum
    Last Post: 10-24-2013, 11:39 PM
  2. Water leaking from exhaust
    Last Post: 10-24-2013, 07:12 PM
  3. Replies: 7
    Last Post: 09-26-2012, 05:37 PM
  4. Johnson 70 hp exhaust smoke and no water at Telltale hose
    By bstephens in forum Johnson Evinrude Outboard Archive
    Last Post: 04-23-2009, 05:43 PM
  5. Water leaking from exhaust y
    By salmonkiller01 in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-06-2006, 11:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
