Electrical problem on start (KAMD44P-B)
adonismon
KAMD44-PBs . When keys turned to start, and active station button pushed on panel, starboard engine will not activate for start. Is flashing the light button is active station. Gauges all come on but panel is dead on starboard side. I have swapped keys, checked all connections, to no avail.
Any Diagnostic Trouble codes? Solid light means Active Station has been captured. Most likely you have to perform calibration procedure on that engine. Calibration will make the ECU re-learn the throttle and shifter travel. Are you using all electronic controls or is your shifter using mechanical control (cable)? Check DTC codes first
