Results 1 to 5 of 5
  1. #1
    Default Have a Gale outboard motor. Need to know year and hp. Also looking for parts to include rings
    Model number GG8834A. Ser number 06X783415. Need to order new rings and gasket set. also impeller and lower end seal kit. not sure if I can just order Johnson parts?
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,886
    Default Re: Have a Gale outboard motor. Need to know year and hp. Also looking for parts to include rings
    What HP is the motor.---Pictures ?-----Many of these motor use OMC internal parts.
  3. #3
    Quote Originally Posted by racerone View Post
    It has been painted camo. so no badging. not sure the hp. was hoping to find the year and hp. than order the same hp and year of a Johnson and see if parts fit.
  4. #4
    Based on the model number being GG8834A, you have a 1960 Montgemry Wards "Sea King" made by Gale. It is 25 hp. Usually the same year/hp evinrde/johnson parts will work for ign, carb, impellers, but not sure about internals like bearings, rings, ect. Unless you have a special connection to this motor, the first thing you might do is check the compression and connecting rod bearings, to determine if it is worth the expense and effort. The motor is not worth more than $250 and most likely half that, this is not a rare motor.
  5. #5
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    14,886
    Any pictures / dimensions of the internal parts ?
Similar Threads
  1. Gale 5HP info and parts help..
    By naturelover in forum Gale Outboards
    Last Post: 10-05-2013, 06:48 PM
  2. ? Gale Sovereign Outboard Motor 60 HP
    By dhoosier in forum Gale Outboards
    Last Post: 06-17-2010, 05:03 AM
  3. Outboard motor gas tank and parts
    By mearley in forum Mercury Mariner Outboard Forum
    Last Post: 05-15-2010, 07:23 PM
  4. Wizard Outboard motor parts
    By larry koob in forum Chrysler Force Outboard Archive
    Last Post: 05-08-2006, 01:00 PM
  5. Need to ID an Old Wards Outboard Motor made by Gale
    By Wally Andy in forum Gale Outboards
    Last Post: 04-13-2004, 05:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
