Carl Jones
I am getting set to pull the motor, I see several possibilities, #1- Pull the drive so the motor will lift out off the mounts, #2- Try taking the motor mounts loose at the base by removing the lag bolts and try moving the motor forward off the drive shaft and then up. #3-Undo the Bell housing bolts and take the motor mounts loose at the base by removing the lag bolts and try moving the motor forward and then up. Can anyone give me the pluses and minuses on these methods. Yhanks for your help!!
