I'm new to outboard engines. I bought a 2002 F4 four-stroke that sat for a long time. I replaced the water pump, lubes, plug, fuel filter and screen. I got it to fire up and it seemed to run pretty good. Once on my sailboat, though, it would only run when choked. As I was working on the boat all summer, the engine sat on its side in the recommended orientation. I brought the motor home, took the carb apart, but one jet is seized in there. Soaked everything and blew with compressed air. Now, I can't get any bit of igniting. I verified that I'm pumping fuel, pulled the plug and found it oil-soaked. Replaced that and verified spark by grounding plug to the intake plenum. Pulled a few times, yanked the plug and found it wet with fuel so that's getting in there. Should I try some starting fluid? The stuff intimidates me. Spray it into the air intake of the carb or remove the plug and blow a shot in there? Thanks much for any advice!
