Hello,
I have had several issues with this motor previously and members helped me solve the problems, so many thanks and here's the next issue.
This is a 1978 BF 7.5hp motor with long shaft.
I got the motor running really well at low speed both cylinders fire and engine runs strong. When the motor transitions to high speed one of the cylinders doesn't fire and it runs rough. I took it to a shop they say compression is good and put in new points but can't fix the problem. They have been working directly with Honda and can't figure it out. When I first brought it in to the shop they said this is a great little motor and is in really good condition. Previous issues were out of time (so badly it wouldn't start), leaking oil fill tube seal, carb clean needed (I put on a brand new one, problem existed before and after), and needed points.
Thanks in advance,
Thanks in advance,
