manual valve springs
frmach
Nissan ns50d2.
There are two springs in the tilt/trim manual valve. They are both the same dia and length.
One is stronger than the other. Which one goes into the cylinder first?
Thanks:confused:
You must have the old style cylinder... the 2 springs are separated by the 3B7771740M COLLAR INNER. 3C8772230M (no longer available) goes in first, then the collar, then 3B7771720M. See your FSM for more details.
How do I know which is which.One is stronger than the other. That is all that I know. I took the valve apart and don't remember which one came out last. What happens if they are reversed?
In your case, I would call Tohatsu America at 214-420-6440 to see if they can help you identify which spring is which.
