i have just got a Chrysler 140 need help
ryancutugno
hi i need help i have a Chrysler 140 it has not run for 2 years i changed the fuel line and cleaned the filters i had it running but i just stopped i dont realy know the parts of it as well dont want to stuff it any help on fixing it up would be great cheers
No.
The unleaded runs just fine.
You can add the Ethanol stabilizer.In the US were pretty much forced to use Ethanol.
I don't add anything.
One thing I do is put a water/fuel seperating filter system.
And check it every 2 months.
Also an inline filter before the fuel pump.
You ended your post with "cheers" most in the US don't.
Fill out the profile and let us know where your from??
The carb air screws need to be set at about 1 and 1/8th to 1/4 out for inital setting.
Then adjust from there.
You have a manual?
